2022.4
Manual: Multi-node HA-ready production profile requirements and installation
This page walks you through the requirements and installation instructions for the multi-node HA-ready production profile.
Deployment Profile Overview
Important:
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath Professional Services.
Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days, and you must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days. For instructions, see Managing certificates.
The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
Federal Information Processing Standard (FIPS) is not compatible with Automation Suite. If FIPs is enabled at any point on the servers running Automation Suite, the cluster will fail. If FIPs is enabled on any cluster server, the installer will encounter issues blocking the installation.
Larger node sizes are more efficient than smaller node sizes because of the fixed baseline resource overhead per node. For example, 3 x 32 cores nodes is more efficient than 6 x 16 cores nodes.
Deployment profile
Prerequisites
Requirements
Configuration
Installation
Minimum 3 Linux machines with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
  • Additional Linux machine is required when using Task Mining
  • Additional Linux machine with GPU support is recommended when using Document Understanding
Note:
  • We support new minor versions of RHEL within 90 days of their release.
  • We support SELinux with default policies.
  • Microsoft SQL Server (2016, 2017, 2019, 2022 - Standard and Enterprise editions)
  • Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
DNS
N/A
TLS 1.2+
N/A
IPv4
Important:
IPv6 is not supported.
N/A
N/A
Trusted TLS, token-signing and SQL connection encryption certificates
N/A
Load balancer
N/A
Proxy server (optional)
N/A
Setting up Kerberos authentication (optional)
N/A
Important:
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libsdnf install -y kernel kernel-tools kernel-tools-libs
Note:
  • You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
  • Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
  • Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
  • UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
Production Deployment — Multi-node HA-ready Production Profile Hardware Requirements
Important:
The minimum hardware requirements do not protect the deployment from node failures.
To understand your storage needs and plan for them accordingly, see Evaluating your storage needs.
If you opt for the multi-node HA-ready production profile, you must meet the following hard requirements:
(the only configuration supported for production deployments)
Selection
Complete
Basic
Node count
At least 3 server nodes.
There must be an odd number of server nodes in a cluster to have increased fault tolerance.
There is no limit on the number of agent nodes
Processor
96 (v-)CPU/cores
48 (v-)CPU/cores
Minimum processor per node
32 (v-)CPU/cores
16 (v-)CPU/cores
RAM total
192 GiB
96 GiB
Minimum RAM per node
64 GiB
32 GiB
Cluster binaries and state disk for each node
256 GiB SSD
Min IOPS: 1100
256 GiB SSD
Min IOPS: 1100
Data disk for each server node
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
etcd disk for each server node
16 GiB SSD
Min IOPS: 240
16 GiB SSD
Min IOPS: 240
UiPath bundle disk
(For offline installation only, on one of the server nodes)
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Objectstore
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Additional agent node for Task Mining (required)
Processor
20 (v-)CPU/cores
N/A
(Task Mining is not present in this selection)
RAM
60 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
Additional agent node with GPU support for Document Understanding
Processor
8 (v-)CPU/cores
N/A (AI Center is not present in this selection)
RAM
52 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
GPU RAM
11 GiB
Note: Larger node sizes are more efficient than smaller node sizes because of the fixed baseline resource overhead per node. For example, 3 x 32 cores nodes is more efficient than 6 x 16 cores nodes.
Microsoft SQL Server general requirements
The installation requires an external SQL server as a prerequisite.
Note: Make sure that the SQL server can be accessed from each cluster VM.
Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
The minimum hardware requirements for Microsoft SQL Server are:
  • 8 (v-)CPU
  • 32 GB RAM
  • 256 GB SSD
  • Deployment Profile Overview
  • Production Deployment — Multi-node HA-ready Production Profile Hardware Requirements
  • Microsoft SQL Server general requirements
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
