- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
This page walks you through the steps for connecting the Task Mining client to the Automation Suite instance.
For Task Mining specific requirements, please refer to the Task Mining client Hardware and software requirements (single-node evaluation and multi-node HA-ready production installations).
This is where you configure your project settings, including which team members will participate and which applications should be recorded.
In order for the invitation email notifications to be delivered, make sure to set up system email notifications.
In case system email notifications are not configured, users will still be successfully added to the project, however, they will not receive an email with the link to the desktop application and sign-in instructions, please make sure to communicate the instructions to users.
Follow these steps to send an email invitation to selected user(s). The resulting email will contain instructions for each user to download and install Task Mining client application.
Each user you have specified will receive an email containing instructions and the link to download the Task Mining client.
Installing the self-signed certificate
This step is only required for the self-signed certificates, which are a default option during the installation.
More information can be found here: Configuring the certificates
If during installation you have opted in for a CA-trusted certificate you can skip this step.
Update the hosts file with values specific to your installation
Follow the same steps used to configure the DNS during installation of Automation Suite to make the FQDN of your Automation Suite installation accessible from the local machine.
Object store host (e.g., objectstore.dns-123.eastus.cloudapp.azure.com) is necessary for the following Task Mining flows:
- Task Mining client application requires the host to push captured data to the Admin Portal.
- Admin portal leverages the host to download data relevant for visualizing the analysis results.
If the host is not specified, the flows do not work.
Install and run the Task Mining client application
Issues connecting to the Automation Suite service URL
- To make sure the certificate changes work, ensure your Service URL and the certificate used for the SSL are allowed in your company network (firewalls, proxy configuration, etc.).
- Make sure to paste the Service URL without the "/" at the end of the string, as it won’t work with the slash in the link.
Cannot find a UiPath® web service at the given address.
Please make sure that you can connect to the Task Mining service in Automation Suite using the browser of choice.
If you are, please follow through the following steps.
If the Task Mining service is not enabled - please make sure to proceed
If not - please make sure to capture the screen and make sure that prerequisites for connecting Task Mining client application (certificate installation, hosts file edit) are met.
- If there is any company to direct traffic through a proxy service - please make sure to configure the proxy service in Task Mining application explicitly.
- If the previous steps didn’t help resolve the issue, please collect application logs and reach out for support.
