2022.4
Adding a dedicated agent Node for Task Mining
Hardware requirements
Before starting the Task Mining installation, make sure to check the Hardware requirements. Task Mining has a dependency on AI Center; therefore, to use Task Mining, you must also install AI Center.
After completing the Automation Suite installation, take the following steps to set up Task Mining.
Enable Task Mining on the Cluster
If you already enabled Task Mining in the configuration during the main install, you can skip this step. If not, you need to enable AI Center and Task Mining by editing the configuration and rerunning the install.
Editing the Configuration
The following needs to be added to the configuration file cluster_config.json during installation in the Advanced Configuration step.
aicenter and task_mining should be added as enabled in cluster_config.json.
cluster_config.json
    "aicenter": {
        "enabled": Boolean
    "task_mining": {
        "enabled": Boolean
    "aicenter": {
        "enabled": Boolean
    "task_mining": {
        "enabled": Boolean
Configuring a Dedicated Node for Task Mining
Step One: Configure the Machine
Follow the steps for configuring a server node to ensure the disk is partitioned correctly.
Step Two: Copy the Interactive Installation Wizard to the Target Machine for Installation
For online installation
SSH to the right machine:
  • If you added Task Mining to a single-node evaluation install, go to the machine and run this next step.
  • If you added Task Mining to a multi-node HA-ready production install, go to any of the server nodes.
Run the following command to copy the contents of the UiPathAutomationSuite folder to the Task Task Mining node (username and DNS are specific to the Task Mining node):
sudo su -
scp -r /opt/UiPathAutomationSuite <username>@<node dns>:/opt/
scp -r ~/* <username>@<node dns>:/opt/UiPathAutomationSuite/sudo su -
For offline installation
SSH to the primary installation node
Ensure that the UiPathAutomationSuite directory contains sf-infra.tar.gz file ( is a part of the installation package download step )
scp -r ~/opt/UiPathAutomationSuite <username>@<node dns>:/var/tmpscp -r ~/opt/UiPathAutomationSuite <username>@<node dns>:/var/tmp
Step Three: Run the Interactive Install Wizard to Configure the Dedicated Node
SSH to the Task Mining Node and run the following commands:
sudo su -
cd /opt/UiPathAutomationSuite
yum install unzip jq -y
CONFIG_PATH=/opt/UiPathAutomationSuite/cluster_config.json
UNATTENDED_ACTION="accept_eula,download_bundle,extract_bundle,join_task_mining" ./installUiPathAS.shsudo su -
Connect via SSH to the Task Mining dedicated node & install the platform bundle on it using the script below.
sudo su
mv /var/tmp/UiPathAutomationSuite /opt
sudo chmod -R 755 /opt/UiPathAutomationSuite
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j task-mining --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreementsudo su
Step Four: Enabling Kubectl
Run below command to set the kubectl context on taskmining machine
sudo su -
export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodessudo su -
kubectl get nodes
You should see the nodes and their corresponding names. You need the name of the Task Mining node for the next step.
Step Five: Verifying Task Mining Configuration
Finally, run the following command to check if the Task Mining node is configured. Please update the \<node name\> with Task Mining node name in below command.
kubectl describe node <node name> | grep -i "taints"kubectl describe node <node name> | grep -i "taints"
Above command should return you the following output
At this point, you have successfully completed the installation for Task Mining. Sign in to the Automation Suite Portal and enable it in the tenant management UX under the Admin section.
Configuring email
You must configure system email notifications as Task Mining relies on the Automation Suite notification system to send emails.
Starting a Task Mining project
For instructions on creating a Task Mining project, see the Task Mining documentation.
Configuring the Task Mining ML Model in AI Center
Follow the steps for the given deployment type, online or offline.
Online and Offline Installations
Before proceeding with the steps below, it is mandatory to start with following the steps from Uploading ML Packages.
After uploading the ML package, follow the listed steps:
  1. Access AI Center home page for your tenant and click on the Create Project button. This project can be named anything you want but we recommend matching it to the name of your Task Mining project.
  2. From the project, navigate to the ML Packages page and then choose Out of the box Packages
  3. Select the UiPath Task Mining package.
  4. Select TMAnalyzerModel and click Submit.
Note: Please always select the latest version of the model packages.
5. Name the package, choose the most recent package version, and click Submit to create a machine-learning deployment package.
Increasing secondary disk/Longhorn storage
As Task Mining is a data-heavy application, we recommend an additional 1024 GB of storage to handle the screenshots and metadata collected during studies. After adding a secondary disk, you must resize the Longhorn storage to incorporate it.
Configuring a new disk in the cluster
You can add the additional disk either pre- or post installation. If you add it post-installation, you must take additional steps to configure the new disk in the cluster.
Increasing storage capacity
To increase the storage capacity after completing the installation, navigate to UiPathAutomationSuite folder and run the following command:
sudo su -
sudo ./configureUiPathAS.sh objectstore resize-pvc --size 1000Gi --sub-component datasudo su -
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
