2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
Take the following steps on one of the cluster server nodes:
Obtain Kubernetes access.
on server nodes: export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" on agent nodes: export KUBECONFIG="/var/lib/rancher/rke2/agent/kubelet.kubeconfig" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" # To validate, execute the following command which should not return an error: kubectl get nodes
on server nodes: export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" on agent nodes: export KUBECONFIG="/var/lib/rancher/rke2/agent/kubelet.kubeconfig" export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin" # To validate, execute the following command which should not return an error: kubectl get nodes -
Retrieve the ArgoCD password by running the following command:
kubectl get secrets/argocd-admin-password -n argocd --template '{{ .data.password }}' | base64 -d
kubectl get secrets/argocd-admin-password -n argocd --template '{{ .data.password }}' | base64 -d - Connect to ArgoCD
- Navigate to
https://alm.<fqdn>/:443
- Login using
admin
as the username and the password obtained at Step 2.
- Navigate to
- Locate the UiPath Services application as follows:
- Using the search bar provided in ArgoCD, type in
uipath
. - Then open the UiPath application by clicking its card.
- Check for the following:
Application was not synced due to a failed job/pod
. - If the above error exists, take the following steps.
- Locate any un-synced components by looking for the red broken heart icon, as shown in the following image.
- Open the right-most component (usually pods) and click the Logs tab. The Logs will contain an error message indicating the reason for the pod failure.
- Once you resolve any outstanding configuration issues, go back to the home page and click the Sync button on the UiPath application.
