- Overview
- Requirements
- Root privileges requirements
- High Availability – three availability zones
- Certificate Requirements
- Network Requirements
- Validating the Prerequisites in a Single-node Evaluation Setup
- Validating the Prerequisites in a Multi-node HA-ready Production Setup
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Before installing Automation Suite, it is good practice to validate the installation prerequisites and infrastructure readiness. You can use the dedicated script to evaluate your environment and generate a summary before performing the installation.
Downloading the Script
sf-installer.zip, and supporting tools are bundled as sf-infra.tar.gz for offline only. You need these files to generate a report on all the machines on which you plan to install Automation Suite.
Installation type |
Files to download |
Online |
sf-installer.zip – Mandatory. For download instructions, see sf-installer.zip.
Offline |
sf-infra.tar.gz – Mandatory. For download instructions, see sf-infra.tar.gz.
Preparing to Use the Script
Become root by running the following command:
sudo su -sudo su - -
Copy the files to the
/opt/UiPathAutomationSuite/{version}folder by running the following command:VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION}VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION} -
Unzip the package by running the following command:
unzip sf-installer.zip -d installerunzip sf-installer.zip -d installer -
Assign the necessary permissions and navigate to the script folder by running the following command:
chmod -R 755 installer cd installerchmod -R 755 installer cd installer
Script Parameters
To view the help section and supported flags, run the following command:
./validateUiPathASReadiness.sh --help./validateUiPathASReadiness.sh --helpOutput:
validateUiPathASReadiness.sh Runs pre-install validation checks
Arguments:
-i|--input Specify cluster config json file
-m|--machines Comma separated IP address / hostnames of all the machines
-n|--node-type Possible values [server|agent|task-mining|gpu]. Defaults to server
--install-type Possible values [online|offline]. Defaults to online
--install-standalone-aicenter Run checks for standalone aicenter service only
--prereq-bundle </uipath/sf-infra.tar.gz> Specify the path to the prereq bundle, only for offline installation
--prereq-tmp-folder </uipath> Specify parent directory for the temporary install folder, only for offline installation
-h|--help Display help
Arguments:
***************************************************************************************The following table describes the parameters you can use when running the script:
Parameter |
Description |
Accepts the
cluster_config.json file as input. This file defines the parameters, settings, and preferences applied to the UiPath services deployed via Automation
Suite. For details, see Advanced Installation Experience.
If you do not provide this file, the script will trigger the interactive experience to collect these inputs. The file will then be generated on your behalf. |
Accepts comma-separated IP address / hostnames of all the machines. This is required to check the connectivity between all the nodes on the required port. The parameter is mandatory for multi-node HA-ready production installations. In addition to that, the parameter is also required if you plan to add a Task Mining or GPU node in a single-node evaluation cluster. |
Accepts the type of the current node. Possible values are:
server, agent, task-mining, and gpu.
The default value is
server.
Accepts the installation method:
online or offline.
online.
This is a Boolean flag. Pass it if you plan to install standalone AI Center. |
Accepts the absolute path where the
sf-infra.tar.gz is located.
sf-infra.tar.gz bundle will be temporarily extracted. If this path is not provided, the installer will select the /tmp folder.
Online
To validate a single-node evaluation machine, run the following command:
./validateUiPathASReadiness.sh \
--node-type server \ # replace server with task-mining, gpu if you wish to install.
--install-type online./validateUiPathASReadiness.sh \
--install-type onlineOffline
To validate a single-node machine, run the following command:
--install-type offline \
--prereq-bundle ../sf-infra.tar.gz \
--prereq-tmp-folder /opt/UiPathAutomationSuite/tmp./validateUiPathASReadiness.sh \
--prereq-tmp-folder /opt/UiPathAutomationSuite/tmpTo validate a Task Mining or a GPU node, take the following steps:
Copy the
cluster_config.jsonfile generated on the server machine to all the agent machines:scp /opt/UiPathAutomationSuite/cluster_config.json <username>@<node dns>:/opt/UiPathAutomationSuitescp /opt/UiPathAutomationSuite/cluster_config.json <username>@<node dns>:/opt/UiPathAutomationSuiteNote:If you are unable to copy the file to the/opt/UiPathAutomationSuitefolder due to permission error, you can temporarily copy it to/var/tmpon the new machines, and then move it to/opt/UiPathAutomationSuite.Alternatively, you can also provide full access permissions (777) to the/opt/UiPathAutomationSuitefolder on the new machines, by running the following command:chmod -R 777 /opt/UiPathAutomationSuite. -
To validate the environment, run the following command on agent machines:
Note: If you run the command on a Task Mining or GPU node, replace--node-type agentwith--node-type task-miningor--node-type gpu, respectively.
Online
--input /opt/UiPathAutomationSuite/cluster_config.json \
--node-type agent \ # replace agent with task-mining, gpu if you wish to install.
--install-type online \ #replace with offline for airgap
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IP of all the nodes in cluster./validateUiPathASReadiness.sh \
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IP of all the nodes in clusterOffline
