2022.4
RKE2 fails during installation and upgrade
Description​
Occasionally, when performing a clean installation or upgrade to Automation Suite 2022.4.11, you may encounter a restart issue disrupting RKE2. This issue usually causes the rke2-server service to enter a failed state.
To verify if you are affected by this specific issue, run the following command to get a more detailed error message:
journalctl -xe -u rke2-server cmd
You should get the following error message:
Solution​
To fix the issue, take the following steps:
  1. Manually restart the rke2-server multiple times until it successfully starts.
    systemctl restart rke2-server
  2. Verify the status of the rek2-server service. If the outcome indicates that the service is active, then the issue has been resolved.
    systemctl status rke2-server and if
  • Description​
  • Solution​
Connect
Stay updated
