- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Manual: Single-node evaluation profile requirements and installation
This page walks you through the requirements and installation instructions for the single-node evaluation profile.
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath Professional Services.
Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days, and you must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days. For instructions, see Managing certificates.
Federal Information Processing Standard (FIPS) is not compatible with Automation Suite. If FIPs is enabled at any point on the servers running Automation Suite, the cluster will fail. If FIPs is enabled on any cluster server, the installer will encounter issues blocking the installation.
Deployment profile |
Prerequisites |
Requirements |
Configuration |
Installation |
Single-node evaluation profile |
One Linux machine (RHEL 8.6, 8.8, or 8.9) with ipcalc tool installed
Note:
DNS | N/A | |||
TLS 1.2+ |
N/A | |||
IPv4 Important:
IPv6 is not supported. |
N/A |
N/A | ||
Trusted TLS, token-signing and SQL connection encryption certificates | N/A | |||
Proxy server (optional) | N/A | |||
Kerberos authentication (optional) |
N/A |
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libs
- You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
- Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
- UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
If you opt for the single-node evaluation profile, you must meet the following hard requirements:
Single-node evaluation profile (supported only for evaluation and demo purposes) | ||
Selection |
Complete |
Basic |
Processor |
32 (v-)CPU/cores |
16 (v-)CPU/cores |
RAM |
64 GiB |
32 GiB |
Cluster binaries and state disk for each node |
256 GiB SSD Min IOPS: 1100 |
Data disk for server node |
512 GiB SSD Min IOPS: 1100 |
512 GiB SSD IOPS: 1100 |
etcd disk for server node |
16 GiB SSD Min IOPS: 240 |
16 GiB SSD IOPS: 240 |
UiPath bundle disk (For offline installation only, on one of the server nodes) |
Objectstore |
Additional agent node for Task Mining (required) | ||
Processor |
20 (v-)CPU/cores |
N/A (Task Mining is not present in this selection) |
RAM |
60 GiB | |
Cluster binaries and state disk |
256 GiB SSD Min IOPS: 1100 | |
Data disk |
N/A | |
Additional agent node with GPU support for Document Understanding | ||
Processor |
8 (v-)CPU/cores |
N/A (AI Center is not present in this selection) |
RAM |
52 GiB | |
Data disk |
N/A | |
GPU RAM |
11 GiB |
The installation requires an external SQL server as a prerequisite.
Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
The minimum hardware requirements for Microsoft SQL Server are:
- 8 (v-)CPU
- 32 GiB RAM
- 256 GiB SSD
