2022.4
Manual, Online: Restoring the Cluster
Before You Begin
  • Make sure you have followed the Prerequisites.
  • Make sure the backup is disabled on the backup cluster. Inconsistencies will occur if a new backup is created while restoring the cluster. See Manual: Disabling the backup on the cluster.
  • Make sure package wget, unzip, jq are available on all the restore nodes.
  • All external data source source should be the same (SQL Server).
  • Restart the NFS server before restoring the cluster. Execute the following command on the NFS server node: systemctl restart nfs-server.
  • The restore cluster must have the same FQDN as the backup cluster.
    Installation type
    configuration instructions
    Requirements
    Online single-node evaluation mode
    Download the following file:
    • sf-installer.zipMandatory. See sf-installer.zip for download instructions.
    Online multi-node HA-ready production mode
Preparing the Restore Operation
Important: If you have multiple nodes in the cluster, follow these steps on all the nodes.
  1. Log into any machine.
  2. To create the /opt/UiPathAutomationSuite folder for the installer, run:
    # Become root
    sudo su -
    # Replace {version} with actual installer version
    mkdir -p /opt/UiPathAutomationSuite/{version}/installer
    chmod -R 777 /opt/UiPathAutomationSuite# Become root
    sudo su -
  3. To copy restore.json and other installer files to the /opt/UiPathAutomationSuite/{version} folder, run:
    cp /path/to/restore.json /opt/UiPathAutomationSuite/{version}/installer
    cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/{version}/installer# Replace {version} with actual installer version
  4. To unzip sf-installer.zip, run:
    # Navigate to installer folder. Replace {version} with actual installer version
    cd /opt/UiPathAutomationSuite/{version}/installer
    unzip sf-installer.zip -d .# Navigate to installer folder. Replace {version} with actual installer version
Restoring Etcd on the First Server Node
To restore etcd on the first node of the cluster, run:
./install-uipath.sh -i ../restore.json -o output.json -r --accept-license-agreement --install-type online./install-uipath.sh -i ../restore.json -o output.json -r --accept-license-agreement --install-type online
Note: This command restores the node configuration on the first server node.
Restoring Etcd on the Remaining Server Nodes
To restore etcd on other nodes of the cluster, run:
./install-uipath.sh -i ../restore.json -o output.json -r -j server --accept-license-agreement --install-type online./install-uipath.sh -i ../restore.json -o output.json -r -j server --accept-license-agreement --install-type online
Note: This command restores the node configuration on the remaining server nodes.
Restoring Etcd on Agent Nodes
To restore etcd on agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j agent --accept-license-agreement --install-type online
Note: This command restores the node configuration on the remaining agent nodes.
Restoring Etcd on Task Mining Nodes
To restore etcd on Task Mining agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j task-mining --accept-license-agreement --install-type online./install-uipath.sh -i restore.json -o output.json -r -j task-mining --accept-license-agreement --install-type online
Note: This command restores the node configuration on the Task Mining nodes.
Restoring Etcd on GPU Nodes
Note: Before restoring the GPU machine, make sure you have followed Installing a GPU driver on the machine.
To restore etcd on GPU agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j gpu --accept-license-agreement --install-type online./install-uipath.sh -i restore.json -o output.json -r -j gpu --accept-license-agreement --install-type online
Note: This command restores the node configuration on the GPU nodes.
Disabling the Maintenance Mode
Note: This step is required only if the restore is part of the rollback operation during upgrade.
Before restoring the volume, you need to disable the maintenance mode:
./configureUiPathAS.sh disable-maintenance-mode./configureUiPathAS.sh disable-maintenance-mode
Running Volume Restore on Any Server Node
After restoring etcd, restore the volume on any of the server nodes by running:
./install-uipath.sh -i restore.json -o output.json -r --volume-restore --accept-license-agreement --install-type online./install-uipath.sh -i restore.json -o output.json -r --volume-restore --accept-license-agreement --install-type online
Note: This command restores the volume data on the cluster.
Enabling AI Center on the Restored Cluster
After restoring an Automation Suite cluster with AI Center™ enabled, follow the steps from the Enabling AI Center on the Restored Cluster procedure.
Restoring Cluster_config.json
Following the Automation Suite cluster recovery, you may want to recover the cluster_config.json for future reference. You may need it when adding new nodes to the cluster, when upgrading, etc.
To restore cluster_config.json, run:
./configureUiPathAS.sh config get -o ./cluster_config.json./configureUiPathAS.sh config get -o ./cluster_config.json
Important: The backup is not enabled on the restored cluster. If you want to enable the backup, see Enabling the backup on the cluster.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
