2022.4
Last updated Mar 17, 2025
All Longhorn replicas are faulted
If the Longhorn replicas are in a faulted state and require manual salvage, the volume may not be able to attach and remain in a detach state.
To check if the volume requires manual salvage, run the following commands:
kubectl  logs -l app=longhorn-manager  -n longhorn-system  -c longhorn-manager --prefix=true  --tail=-1  |grep "set engine salvageRequested to true" | grep <PV NAME>kubectl  logs -l app=longhorn-manager  -n longhorn-system  -c longhorn-manager --prefix=true  --tail=-1  |grep "set engine salvageRequested to true" | grep <PV NAME>
Sample output:
2023-11-20T18:22:16.667609096+11:00 time="2023-11-20T07:22:16Z" level=info msg="All replicas are failed, set engine salvageRequested to true" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=rpa-suite-dev-01.it.csiro.au owner=rpa-suite-dev-01.it.csiro.au state=detaching volume=pvc-031fd6bc-9cfe-420a-9213-da38509d733a2023-11-20T18:22:16.667609096+11:00 time="2023-11-20T07:22:16Z" level=info msg="All replicas are failed, set engine salvageRequested to true" accessMode=rwo controller=longhorn-volume frontend=blockdev migratable=false node=rpa-suite-dev-01.it.csiro.au owner=rpa-suite-dev-01.it.csiro.au state=detaching volume=pvc-031fd6bc-9cfe-420a-9213-da38509d733a
Solution
To fix this issue, take the following steps:
  1. Scale down the workload pods.
  2. Find replicas of the relevant volume by running the following command:
    kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME>kubectl get replicas.longhorn.io -n longhorn-system |grep <PV_NAME>
  3. Edit the replicas.longhorn.io object for the relevant PV by running the following command and set the spec.failedat field to empty(““).
  4. Scale up the workload pods.
  • Description
  • Solution
