- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
- Make sure you have followed the Prerequisites.
- Make sure the backup is disabled on the backup cluster. Inconsistencies will occur if a new backup is created while restoring the cluster. For details, see Automated: Disabling the backup on the cluster.
- Make sure package wget, unzip, jq are available on all the restore nodes.
- All external data sources must be the same (SQL Server).
- You must restart the NFS server before cluster restoration. To do that, run the following command on the NFS Server node:
systemctl restart nfs-server. - The restore cluster must have the same FQDN as the backup cluster.
- Make sure you have prepared your environment for using
uipathctl.shcommand. For details, see Using uipathctl.sh. -
At the time of cluster restore, you must provide the
inventory.inifile containing the IP address of the Ansible host node and information on how to SSH to all nodes. Theuipathctl.shscript cannot generate this file automatically as the cluster is not present at the time of the restore process.Installation type
Configuration instructions
Requirements
Offline single-node evaluation mode
Download the following files:
sf-installer.zip– Mandatory. See sf-installer.zip for download instructions.sf-infra.tar.gz– Mandatory. See sf-infra.tar.gz for download instructions.
Offline multi-node HA-ready production mode
Download below files
Server 1, which is the Ansible host node, uses Ansible to orchestrate the restore of all the nodes in the cluster.
uipathctl.sh script:
inventory.ini– This file contains information on all the nodes in the cluster and SSH details. Theuipathctl.shscript does not generate theinventory.inifile automatically as the cluster is not present at the time of cluster restore.restore.json– This file contains the restore configuration. For details, see Preparing the restore configuration section.
To restore the cluster, run the following command with the basic parameters. Make sure to use the parameter values applicable to you.
./uipathctl.sh restore --install-type online --restore-config ./restore.json --inventory ./inventory.ini --offline-infra-bundle ../sf-infra.tar.gz
Basic Parameters
Parameter |
Description |
Possible values:
online and offline.
Since this page provides restore instructions for online, choose the
offline value.
The file contains the restore configuration. For details, see Preparing the restore configuration. |
The file contains information on all the nodes in the cluster, and SSH details. For details, see Generating the Ansible inventory.ini file. |
Advanced Parameters
Parameter |
Description |
Specify the username that you will use for SSH connections to all the nodes. Defaults to the current user. If you use a different username for all the nodes, instead of using this parameter, set the username for all the nodes in
inventory.ini and pass it to the script.
Example: While running the script you are logged in as the
myadminuser username. However, if you want to use the testadmin username to connect via SSH, you must provide testadmin to a value for this parameter.
cluster_config.json for future reference. You may need the file when adding new nodes to cluster, when upgrading, etc.
cluster_config.json, run the following command from any of the server nodes:
./configureUiPathAS.sh config get -o ./cluster_config.json./configureUiPathAS.sh config get -o ./cluster_config.jsonThe backup is not enabled on the restored cluster. If you wish to enable it, refer to Enabling the backup on the cluster.
Restoring the cluster is not an idempotent operation. In case of a failed restore, take one of the following steps before retrying the operation:
- Uninstall Automation Suite on all the nodes. For instructions, see Troubleshooting.
- Follow the manual restore steps. For instructions, see Manual, online: Restoring the cluster.
After restoring the cluster, make sure to add your CA certificates to the trust store of the restored VMs. For details, see:
