- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
- Disabling the cluster backup will cause data loss. The operation will affect data created between the last scheduled backup and the time you disabled the backup.
- To disable the backup, you need to perform the operation on all the server nodes of the cluster.
You can perform this operation on any server node in the cluster. Note that this operation entails disabling etcd (cluster configuration) and data backup at the same time. This setup alone will not disable the backup on the entire cluster. You must disable the backup on the other server nodes as well, if there are any.
To disable etcd and data backup, run:
./install-uipath.sh -i backup.json -o output.json -b --disable-backup --accept-license-agreement
This operation disables the etcd backup on the other server nodes. You need to perform this step on the remaining server nodes. You do not have to disable data backup. This is because data backup is not node-specific, but at a cluster level, which you have already disabled via the previous command.
./install-uipath.sh -i backup.json -o output.json -b -j server --disable-backup --accept-license-agreement
