- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Installation best practices
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
We recommend rotating certificates before their expiration date. Make sure to schedule a downtime period to address potential issues. To be informed in a timely manner of the certificate expiration dates, configure alerts for your cluster. Doing so prevents service disruptions. For more details, see Alert runbooks.
We highly recommend performing the following yearly maintenance tasks:
Renew the SSL certificate. For details, see Managing server certificates.
Renew the identity certificate. For details, see Managing identity token-signing certificates .
Renew the internal Kubernetes certificate. For details, see Managing Rancher certificates.
Renew the cattle webhooks certificate. For details, see the Rancher documentation.
Clean up logs manually. For details, see How to clean up logs.
