2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
You might get an error that the certificate is signed by an unknown authority.
Error: failed to do request: Head "https://sfdev1778654-9f843b23-lb.westeurope.cloudapp.azure.com:30071/v2/helm/audit-service/blobs/sha256:09bffbc520ff000b834fe1a654acd089889b09d22d5cf1129b0edf2d76554892": x509: certificate signed by unknown authorityError: failed to do request: Head "https://sfdev1778654-9f843b23-lb.westeurope.cloudapp.azure.com:30071/v2/helm/audit-service/blobs/sha256:09bffbc520ff000b834fe1a654acd089889b09d22d5cf1129b0edf2d76554892": x509: certificate signed by unknown authorityBoth the rootCA and the server certificates need to be in the trusted store on the machine.
To investigate, execute the following commands:
[root@server0 ~]# find /etc/pki/ca-trust/source{,/anchors} -maxdepth 1 -not -type d -exec ls -1 {} +
/etc/pki/ca-trust/source/anchors/rootCA.crt
/etc/pki/ca-trust/source/anchors/server.crt[root@server0 ~]# find /etc/pki/ca-trust/source{,/anchors} -maxdepth 1 -not -type d -exec ls -1 {} +
/etc/pki/ca-trust/source/anchors/server.crtThe provided certificates need to be in the output of those commands.
Alternatively, execute the following command:
[root@server0 ~]# openssl x509 -in /etc/pki/ca-trust/source/anchors/server.crt -text -noout[root@server0 ~]# openssl x509 -in /etc/pki/ca-trust/source/anchors/server.crt -text -nooutEnsure that the fully qualified domain name is present in the Subject Alternative Name from the output.
[root@server0 ~]# openssl x509 -in /etc/pki/ca-trust/source/anchors/server.crt -text -noout[root@server0 ~]# openssl x509 -in /etc/pki/ca-trust/source/anchors/server.crt -text -nooutYou can update the CA Certificate as follows:
[root@server0 ~]# update-ca-trust[root@server0 ~]# update-ca-trust
