2022.4
RabbitMQ pod stuck in CrashLoopBackOff
This issue causes the RabbitMQ pod to be stuck in CrashLoopBackOff, with the log of the failing pod showing wal_checksum_validation_failure as a reason.
To get a list of all pods, run the following command:
kubectl -n rabbitmq get podskubectl -n rabbitmq get pods
To get the logs of a pod, run the following command:
kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>
Solution
To fix the issue, take the following steps:
  1. Find the number of RabbitMQ replicas:
    rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas')rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas')
  2. Scale down the RabbitMQ replicas:
    kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=mergekubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=merge
    kubectl -n rabbitmq scale sts rabbitmq-server --replicas=0kubectl -n rabbitmq scale sts rabbitmq-server --replicas=0
  3. Wait until all RabbitMQ pods are terminated:
    kubectl -n rabbitmq get podkubectl -n rabbitmq get pod
  4. Check for pending volume snapshots:
    kubectl get volumesnapshot -n rabbitmq  <crashloopbackupoff_pod_pvc_name> | grep falsekubectl get volumesnapshot -n rabbitmq  <crashloopbackupoff_pod_pvc_name> | grep false
  5. If any pending volume snapshot exists, delete it:
    kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name>kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name>
  6. Find and delete the PVC of the RabbitMQ pod that is stuck in the CrashLoopBackOff state:
    kubectl -n rabbitmq get pvckubectl -n rabbitmq get pvc
    kubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name>kubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name>
  7. Scale up the RabbitMQ replicas:
    kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=mergekubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=merge
  8. Check if all RabbitMQ pods are healthy:
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
