2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
If Ceph is unhealthy due to out-of-storage issues, Objectstore PVC resize does not heal it.
To speed up the Ceph recovery in a non-HA cluster, run the following command:
function set_ceph_pool_config_non_ha() {
# Return if HA
[[ "$(kubectl -n rook-ceph get cephobjectstore rook-ceph -o jsonpath='{.spec.dataPool.replicated.size}')" -eq 1 ]] || return
# Set pool size and min_size
kubectl -n "rook-ceph" exec deploy/rook-ceph-tools – ceph osd pool set "device_health_metrics" "size" "1" --yes-i-really-mean-it || true
kubectl -n "rook-ceph" exec deploy/rook-ceph-tools – ceph osd pool set "device_health_metrics" "min_size" "1" --yes-i-really-mean-it || true
}function set_ceph_pool_config_non_ha() {
# Return if HA
