- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Downloading the installation packages
| Package | Purpose |
UiPath.OrganizationMigrationApp |
This page provides instructions on downloading the files to the home directory of the current user. If you want to change the directory, make sure to provide the path to download using the -O parameter.
installUiPathAS.sh
installUiPathAS.sh is an interactive installer wizard that you can use to accept the installation configuration and start the installation.
installUiPathAS.sh is required for both online and offline installation profiles and is used during a fresh installation and for adding a new node to the cluster.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.15/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.15/installUiPathAS.sh -
Windows:
To download
installUiPathAS.shon a Windows machine, click here.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.14/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.14/installUiPathAS.sh -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.13/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.13/installUiPathAS.sh -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.12/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.12/installUiPathAS.sh -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.11/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.11/installUiPathAS.sh -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.10/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.10/installUiPathAS.sh -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.9/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.9/installUiPathAS.sh -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.8/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.8/installUiPathAS.sh -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.7/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.7/installUiPathAS.sh -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.6/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.6/installUiPathAS.sh -
Windows:
To download
2022.4.5
We have removed the Automation Suite 2022.4.5 installation packages due to a major bug affecting Automation Ops. We recommend upgrading to Automation Suite 2022.4.6 instead, which includes a bug fix for Automation Ops.
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.4/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.4/installUiPathAS.sh -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.3/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.3/installUiPathAS.sh -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.2/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.2/installUiPathAS.sh -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.1/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.1/installUiPathAS.sh -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/installUiPathAS.sh
Linux:
To download
installUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.0/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.4.0/installUiPathAS.sh -
Windows:
To download
sf-installer.zip
sf-installer.zip is an installation package that contains the main installation and supporting scripts.
If you choose the offline installation profile, you must download sf-installer.zip. If you opt for the online installation profile, sf-installer.zip is automatically downloaded by the interactive installation wizard.
The sf-installer.zip file is required during installation, upgrade, cluster restore in the event of disaster, and while adding new node to existing cluster.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/installer-2022.4.15.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.15/installer-2022.4.15.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.15/installer-2022.4.15.zip -
Windows:
To download
sf-installer.zipon a Windows machine, click here and rename the file tosf-installer.zip.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/installer-2022.4.14.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.14/installer-2022.4.14.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.14/installer-2022.4.14.zip -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/installer-2022.4.13.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.13/installer-2022.4.13.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.13/installer-2022.4.13.zip -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/installer-2022.4.12.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.12/installer-2022.4.12.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.12/installer-2022.4.12.zip -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/installer-2022.4.11.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.11/installer-2022.4.11.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.11/installer-2022.4.11.zip -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/installer-2022.4.10.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.10/installer-2022.4.10.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.10/installer-2022.4.10.zip -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/installer-2022.4.9.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.9/installer-2022.4.9.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.9/installer-2022.4.9.zip -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/installer-2022.4.8.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.8/installer-2022.4.8.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.8/installer-2022.4.8.zip -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/installer-2022.4.7.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.7/installer-2022.4.7.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.7/installer-2022.4.7.zip -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/installer-2022.4.6.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.6/installer-2022.4.6.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.6/installer-2022.4.6.zip -
Windows:
To download
2022.4.5
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/installer-2022.4.4.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.4/installer-2022.4.4.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.4/installer-2022.4.4.zip -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/installer-2022.4.3.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.3/installer-2022.4.3.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.3/installer-2022.4.3.zip -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/installer-2022.4.2.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.2/installer-2022.4.2.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.2/installer-2022.4.2.zip -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/installer-2022.4.1.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.1/installer-2022.4.1.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.1/installer-2022.4.1.zip -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/installer-2022.4.0.zip
Linux:
To download
sf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.0/installer-2022.4.0.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.4.0/installer-2022.4.0.zip -
Windows:
To download
sf.tar.gz
sf.tar.gz contains the container images and deployment manifests of UiPath Shared Capabilities and UiPath Product. The bundle is approximately 25 GiB in size.
If you opt for the offline installation profile, you must download sf.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly from the container registry hosted in UiPath servers.
sf.tar.gz is required during installation and upgrade only on server node when using internal Docker registry.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/sf-2022.4.15.tar.gz
Checksum file available here.
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.15/sf-2022.4.15.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.15/sf-2022.4.15.tar.gz -
Windows:
To download
sf.tar.gz, click here and rename the file tosf.tar.gz.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/sf-2022.4.14.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.14/sf-2022.4.14.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.14/sf-2022.4.14.tar.gz -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/sf-2022.4.13.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.13/sf-2022.4.13.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.13/sf-2022.4.13.tar.gz -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/sf-2022.4.12.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.12/sf-2022.4.12.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.12/sf-2022.4.12.tar.gz -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/sf-2022.4.11.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.11/sf-2022.4.11.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.11/sf-2022.4.11.tar.gz -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/sf-2022.4.10.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.10/sf-2022.4.10.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.10/sf-2022.4.10.tar.gz -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/sf-2022.4.9.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.9/sf-2022.4.9.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.9/sf-2022.4.9.tar.gz -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/sf-2022.4.8.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.8/sf-2022.4.8.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.8/sf-2022.4.8.tar.gz -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/sf-2022.4.7.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.7/sf-2022.4.7.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.7/sf-2022.4.7.tar.gz -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/sf-2022.4.6.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.6/sf-2022.4.6.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.6/sf-2022.4.6.tar.gz -
Windows:
To download
2022.4.5
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/sf-2022.4.4.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.4/sf-2022.4.4.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.4/sf-2022.4.4.tar.gz -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/sf-2022.4.3.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.3/sf-2022.4.3.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.3/sf-2022.4.3.tar.gz -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/sf-2022.4.2.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.2/sf-2022.4.2.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.2/sf-2022.4.2.tar.gz -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/sf-2022.4.1.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.1/sf-2022.4.1.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.1/sf-2022.4.1.tar.gz -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/sf-2022.4.0.tar.gz
Linux:
To download
sf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.0/sf-2022.4.0.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.4.0/sf-2022.4.0.tar.gz -
Windows:
To download
sf-infra.tar.gz
sf-infra.tar.gz contains Kubernetes packages and other tools needed to install the cluster infrastructure.
If you choose the offline installation profile, you must download sf-infra.tar.gz. If you opt for the online installation profile, the installer will pull these tools directly from UiPath trusted RPM registries.
sf-infra.tar.gz is required during installation, upgrade, cluster restore in the event of disaster, and while adding a new node to the existing cluster.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/sf-infra-only-2022.4.15.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.15/sf-infra-only-2022.4.15.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.15/sf-infra-only-2022.4.15.tar.gz -
Windows:
To download
sf-infra.tar.gzon a Windows machine, click here and rename the file tosf-infra.tar.gz.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/sf-infra-only-2022.4.14.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.14/sf-infra-only-2022.4.14.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.14/sf-infra-only-2022.4.14.tar.gz -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/sf-infra-only-2022.4.13.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.13/sf-infra-only-2022.4.13.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.13/sf-infra-only-2022.4.13.tar.gz -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/sf-infra-only-2022.4.12.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.12/sf-infra-only-2022.4.12.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.12/sf-infra-only-2022.4.12.tar.gz -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/sf-infra-only-2022.4.11.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.11/sf-infra-only-2022.4.11.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.11/sf-infra-only-2022.4.11.tar.gz -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/sf-infra-only-2022.4.10.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.10/sf-infra-only-2022.4.10.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.10/sf-infra-only-2022.4.10.tar.gz -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/sf-infra-only-2022.4.9.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.9/sf-infra-only-2022.4.9.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.9/sf-infra-only-2022.4.9.tar.gz -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/sf-infra-only-2022.4.8.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.8/sf-infra-only-2022.4.8.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.8/sf-infra-only-2022.4.8.tar.gz -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/sf-infra-only-2022.4.7.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.7/sf-infra-only-2022.4.7.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.7/sf-infra-only-2022.4.7.tar.gz -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/sf-infra-only-2022.4.6.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.6/sf-infra-only-2022.4.6.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.6/sf-infra-only-2022.4.6.tar.gz -
Windows:
To download
2022.4.5
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/sf-infra-only-2022.4.4.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.4/sf-infra-only-2022.4.4.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.4/sf-infra-only-2022.4.4.tar.gz -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/sf-infra-only-2022.4.3.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.3/sf-infra-only-2022.4.3.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.3/sf-infra-only-2022.4.3.tar.gz -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/sf-infra-only-2022.4.2.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.2/sf-infra-only-2022.4.2.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.2/sf-infra-only-2022.4.2.tar.gz -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/sf-infra-only-2022.4.1.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.1/sf-infra-only-2022.4.1.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.1/sf-infra-only-2022.4.1.tar.gz -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/sf-infra-only-2022.4.0.tar.gz
Linux:
To download
sf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.0/sf-infra-only-2022.4.0.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.4.0/sf-infra-only-2022.4.0.tar.gz -
Windows:
To download
Du-ondemand.tar.gz
du-ondemand.tar.gz contains base images to install Document Understanding packages.
If you opt for the offline installation profile, you need to download du-ondemand.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly from the container registry hosted in UiPath servers.
du-ondemand.tar.gz is required only when Document Understanding is installed.
For download instructions, see ML Packages Offline Installation.
After downloading Document Understanding packages, make sure to rename them to du-ondemand.tar.gz.
cv-ondemand.tar.gz
cv-ondemand.tar.gz contains Computer Vision models and packages.
If you opt for the offline installation profile, you must download cv-ondemand.tar.gz. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the container registry hosted in UiPath® servers.
cv-ondemand.tar.gz is required only when you want to use Computer Vision models.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/cv-2022.4.15.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.15/cv-2022.4.15.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.15/cv-2022.4.15.tar.gz -
Windows:
To download
cv-ondemand.tar.gzon a Windows machine, click here and rename the file tocv-ondemand.tar.gz.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/cv-2022.4.14.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.14/cv-2022.4.14.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.14/cv-2022.4.14.tar.gz -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/cv-2022.4.13.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.13/cv-2022.4.13.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.13/cv-2022.4.13.tar.gz -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/cv2204-2022.4.12.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.12/cv2204-2022.4.12.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.12/cv2204-2022.4.12.tar.gz -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/cv2204-2022.4.11.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.11/cv2204-2022.4.11.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.11/cv2204-2022.4.11.tar.gz -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/cv2204-2022.4.10.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.10/cv2204-2022.4.10.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.10/cv2204-2022.4.10.tar.gz -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/cv2204-2022.4.9.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.9/cv2204-2022.4.9.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.9/cv2204-2022.4.9.tar.gz -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/cv2204-2022.4.8.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.8/cv2204-2022.4.8.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.8/cv2204-2022.4.8.tar.gz -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/cv2204-2022.4.7.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.7/cv2204-2022.4.7.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.7/cv2204-2022.4.7.tar.gz -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/cv2204-2022.4.6.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.6/cv2204-2022.4.6.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.6/cv2204-2022.4.6.tar.gz -
Windows:
To download
2022.4.5
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/cv2204-2022.4.4.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.4/cv2204-2022.4.4.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.4/cv2204-2022.4.4.tar.gz -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/cv2204-2022.4.3.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.3/cv2204-2022.4.3.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.3/cv2204-2022.4.3.tar.gz -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/cv2204-2022.4.2.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.2/cv2204-2022.4.2.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.2/cv2204-2022.4.2.tar.gz -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/cv2204-2022.4.1.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.1/cv2204-2022.4.1.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.1/cv2204-2022.4.1.tar.gz -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/cv2204-2022.4.0.tar.gz
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.0/cv2204-2022.4.0.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.4.0/cv2204-2022.4.0.tar.gz -
Windows:
To download
ConfigureUiPathDisks.sh
You can use configureUiPathDisks.sh to partition the disk before installation.
The latest version of the script works across all 2022.4.x versions of Automation Suite.
https://download.uipath.com/automation-suite/configureUiPathDisks.sh
Linux:
To download
configureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/configureUiPathDisks.sh -
Windows:
To download
configureUiPathDisks.shon a Windows machine, click here.
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2022.4.17
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.17-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.17-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, click here.
2022.4.16
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.16-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.16-linux.zip -
Windows
2022.4.15
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.15-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.15-linux.zip -
Windows
2022.4.14
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.14-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.4.14-linux.zip -
Windows
2022.4.12
Linux
wget https://download.uipath.com/versions/22.4.12/MSIToAutomationSuiteTenantMigrator-2022.4.12-linux.zipwget https://download.uipath.com/versions/22.4.12/MSIToAutomationSuiteTenantMigrator-2022.4.12-linux.zip -
Windows
2022.4.11
Linux
wget https://download.uipath.com/versions/22.4.11/MSIToAutomationSuiteTenantMigrator-2022.4.11-linux.zipwget https://download.uipath.com/versions/22.4.11/MSIToAutomationSuiteTenantMigrator-2022.4.11-linux.zip -
Windows
2022.4.10
Linux
wget https://download.uipath.com/versions/22.4.10/MSIToAutomationSuiteTenantMigrator-2022.4.10-linux.zipwget https://download.uipath.com/versions/22.4.10/MSIToAutomationSuiteTenantMigrator-2022.4.10-linux.zip -
Windows
2022.4.9
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal, then unzip the archive:
wget https://download.uipath.com/versions/22.4.9/MSIToAutomationSuiteTenantMigrator-2022.4.9-linux.zipwget https://download.uipath.com/versions/22.4.9/MSIToAutomationSuiteTenantMigrator-2022.4.9-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, click here, and unzip the archive.
2022.4.8
Linux
wget https://download.uipath.com/versions/22.4.8/MSIToAutomationSuiteTenantMigrator-2022.4.8-linux.zipwget https://download.uipath.com/versions/22.4.8/MSIToAutomationSuiteTenantMigrator-2022.4.8-linux.zip -
Windows
Supportability-tools
The latest version of supportability-tools works with all Automation Suite versions.
https://download.uipath.com/automation-suite/2022.4.15/supportability-tools-2022.4.15.zip
Linux:
To download
supportability-toolson a Linux machine, run the following command from the terminal:wget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2022.4.15/supportability-tools-2022.4.15.zipwget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2022.4.15/supportability-tools-2022.4.15.zip -
Windows:
To download
supportability-toolson a Windows machine, click here and rename the file tosupportability-tools.
Ansible.tar.gz
ansible.tar.gz contains Ansible and other dependent packages needed for the automated backup and restore as well as automated upgrade operations.
2022.4.15
https://download.uipath.com/automation-suite/2022.4.15/ansible-2022.4.15.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.15/ansible-2022.4.15.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.15/ansible-2022.4.15.tar.gz -
Windows:
To download
ansible.tar.gzon a Windows machine, click here.
2022.4.14
https://download.uipath.com/automation-suite/2022.4.14/ansible-2022.4.14.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.14/ansible-2022.4.14.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.14/ansible-2022.4.14.tar.gz -
Windows:
To download
2022.4.13
https://download.uipath.com/automation-suite/2022.4.13/ansible-2022.4.13.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.13/ansible-2022.4.13.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.13/ansible-2022.4.13.tar.gz -
Windows:
To download
2022.4.12
https://download.uipath.com/automation-suite/2022.4.12/ansible-2022.4.12.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.12/ansible-2022.4.12.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.12/ansible-2022.4.12.tar.gz -
Windows:
To download
2022.4.11
https://download.uipath.com/automation-suite/2022.4.11/ansible-2022.4.11.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.11/ansible-2022.4.11.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.11/ansible-2022.4.11.tar.gz -
Windows:
To download
2022.4.10
https://download.uipath.com/automation-suite/2022.4.10/ansible-2022.4.10.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.10/ansible-2022.4.10.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.10/ansible-2022.4.10.tar.gz -
Windows:
To download
2022.4.9
https://download.uipath.com/automation-suite/2022.4.9/ansible-2022.4.9.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.9/ansible-2022.4.9.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.9/ansible-2022.4.9.tar.gz -
Windows:
To download
2022.4.8
https://download.uipath.com/automation-suite/2022.4.8/ansible-2022.4.8.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.8/ansible-2022.4.8.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.8/ansible-2022.4.8.tar.gz -
Windows:
To download
2022.4.7
https://download.uipath.com/automation-suite/2022.4.7/ansible-2022.4.7.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.7/ansible-2022.4.7.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.7/ansible-2022.4.7.tar.gz -
Windows:
To download
2022.4.6
https://download.uipath.com/automation-suite/2022.4.6/ansible-2022.4.6.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.6/ansible-2022.4.6.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.6/ansible-2022.4.6.tar.gz -
Windows:
To download
2022.4.5
https://download.uipath.com/automation-suite/2022.4.5/ansible-2022.4.5.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.5/ansible-2022.4.5.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.5/ansible-2022.4.5.tar.gz -
Windows:
To download
2022.4.4
https://download.uipath.com/automation-suite/2022.4.4/ansible-2022.4.4.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.4/ansible-2022.4.4.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.4/ansible-2022.4.4.tar.gz -
Windows:
To download
2022.4.3
https://download.uipath.com/automation-suite/2022.4.3/ansible-2022.4.3.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.3/ansible-2022.4.3.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.3/ansible-2022.4.3.tar.gz -
Windows:
To download
2022.4.2
https://download.uipath.com/automation-suite/2022.4.2/ansible-2022.4.2.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.2/ansible-2022.4.2.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.2/ansible-2022.4.2.tar.gz -
Windows:
To download
2022.4.1
https://download.uipath.com/automation-suite/2022.4.1/ansible-2022.4.1.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.1/ansible-2022.4.1.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.1/ansible-2022.4.1.tar.gz -
Windows:
To download
2022.4.0
https://download.uipath.com/automation-suite/2022.4.0/ansible-2022.4.0.tar.gz
Linux:
To download
ansible.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.0/ansible-2022.4.0.tar.gzwget -O ~/ansible.tar.gz https://download.uipath.com/automation-suite/2022.4.0/ansible-2022.4.0.tar.gz -
Windows:
To download
- Overview
- installUiPathAS.sh
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
- sf-installer.zip
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
- sf.tar.gz
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
- sf-infra.tar.gz
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
- Du-ondemand.tar.gz
- cv-ondemand.tar.gz
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
- ConfigureUiPathDisks.sh
- UiPath.OrganizationMigrationApp
- 2022.4.17
- 2022.4.16
- 2022.4.15
- 2022.4.14
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- Supportability-tools
- Ansible.tar.gz
- 2022.4.15
- 2022.4.14
- 2022.4.13
- 2022.4.12
- 2022.4.11
- 2022.4.10
- 2022.4.9
- 2022.4.8
- 2022.4.7
- 2022.4.6
- 2022.4.5
- 2022.4.4
- 2022.4.3
- 2022.4.2
- 2022.4.1
- 2022.4.0
