2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Repaving a cluster node, also known as the rehydration process, may be required in the following scenarios:
- When performing a patch upgrade to the host operating system or software;
- When a security policy requires that you regularly rotate nodes in the cluster;
- When your organization imposes any other policy restrictions.
Direct maintenance on the node that is already part of cluster can interfere with the installed software and network manager, cause cluster instability, and result in downtime.
To prevent these issues, take the following steps to rotate nodes:
For details steps on how to add or remove a node from the cluster, see:
