- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Failed Status When Creating a Data Labeling Session
If you are not able to create data labeling sessions on Data Manager in AI Center, take the following steps.
Solution 1
Please double-check if Document Understanding is properly enabled. You should have updated the configuration file before the installation and set documentunderstanding.enabled to True, or you could update it in ArgoCD post-installation as below.
After doing that, you need to disable it and disable AI Center on the tenant you wish to use the Data Labeling feature on, or create a new tenant.
Solution 2
If Document Understanding is properly enabled in the configuration file or ArgoCD, sometimes Document Understanding is not enabled for DefaultTenant. This manifests itself as not being able to create data labeling sessions.
To fix this, disable AI Center on the tenant and re-enable it. Note that you might need to wait a few minutes before being able to re-enable it.
