2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Generate the latest
cluster_config.json file as follows:
Option A: If you have the old
cluster_config.json, generate the configuration file from the cluster by running the following command on the server node:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.json -
Option B: If you do not have the old
cluster_config.jsonfile, generate an override of any default values resulted during the installation of the previous version by running the following command on the server node:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.json
Note:
For details on how to configure the
cluster_config.json parameters, see Advanced installation experience.
You must provide the database connection string to the restored databases.
To provide the restored connection string to the Orchestrator service, add or update
sql_connection_strunderorchestratorin thefile:cluster_config.json"orchestrator": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true }"orchestrator": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true } -
If Test Automation tables are placed inside the standalone Orchestrator database, you can add the same connection string for Test Automation feature inside the
cluster_config.jsonfile:"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchesrator connection string>" }, "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true }"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchesrator connection string>" }, "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true } -
To provide the restored connection string to the Insights service, add or update
sql_connection_strunderinsightsin thecluster_config.jsonfile."insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }"insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }
Note: Make sure you escape special characters in the
connection string's password.
Online
To run the service installer in an online environment, run the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementOffline
To run the service installer in an offline environment, use the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
