Automation Suite
2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite Installation Guide
Last updated Apr 24, 2024
Pods in RabbitMQ or cattle-monitoring-system or other StatefulSet pods are stuck in the init state.
Occasionally, upon node power failure or during upgrade, an issue causes the pods in RabbitMQ or cattle-monitoring-system to get stuck in init state as the volume required for attaching the PVC to a pod is missing.
Verify if the problem is indeed related to the StatefulSet volume attachment by running the following command:
kubectl -n <namespace> describe pod <pod-name> | grep "cannot get resource \"volumeattachments\" in API group \" storage.k8s.io\""
If it is related to the StatefulSet volume attachment, it will show an error message.
