- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Upgrading Automation Suite enables maintenance mode on the cluster, which causes downtime for the entire upgrade duration.
If your Automation Suite cluster was ever on 2021.10.3 or 2021.10.4, you must take additional steps to downgrade the Ceph objectstore version before upgrading to a newer Automation Suite version. For instructions, see Downgrading Ceph from 16.2.6 to 15.2.9.
- Make sure you meet the hardware and software requirements for new Automation Suite version. If AI Center is enabled, make sure you meet the CUDA requirements.
Download the required installer and bundle files:
Installation type
Files to download
Online
sf-installer.zip– Mandatory. See sf-installer.zip for download instructions.
Offline
sf-installer.zip– Mandatory. See sf-installer.zip for download instructions.sf-infra.tar.gz– Mandatory. See sf-infra.tar.gz for download instructions.sf.tar.gz– Mandatory. See sf.tar.gz for download instructions.
Important:It is strongly recommended to create a backup of the cluster and the SQL database before upgrading Automation Suite. This is to ensure you can restore the cluster if something goes wrong during the upgrade operation.
Cluster data is backed up on NFS server. Make sure you have configured NFS server before proceeding further.
The following illustration shows the steps you need to take for a successful upgrade operation.
For a complete upgrade operation, follow these steps:
- Configure a backup before upgrading the cluster to a new version, if possible.
- Enable maintenance mode on the cluster, by bringing down the cluster network, to avoid any writes during upgrade. This step ensures the upgrade is consistent.
- Upgrade Kubernetes and other infrastructure components on all the cluster nodes.
- For offline installations, hydrate Private Docker Registry with the new container images.
- Upgrade the fabric and shared components on the cluster.
- Upgrade the services (UiPath products).
- Bring back the cluster by disabling the maintenance mode on the cluster.
The following matrix shows the available upgrade paths for Automation Suite versions:
- a direct in-place upgrade path between major versions is available;
- an intermediate in-place upgrade between your initial and targeted major versions is needed.
We strongly advise upgrading to the most recent minor version of Automation Suite. This allows you to take advantage of the latest enhancements and guarantees the seamless operation of all internal components.
Initial version |
Targeted version | ||||
2021.10.x |
2022.4.x |
2022.10.x |
2023.4.x |
2023.10.x | |
2021.10.x |
2022.4.x |
N/A |
Requires 2022.4.7 minimum with Ceph on raw devices, and completion of Cilium migration before initiating the upgrade.
2022.10.x |
N/A |
N/A |
2023.4.x |
N/A |
N/A |
N/A |
2023.10.x |
N/A |
N/A |
N/A |
N/A |
In some cases, upgrading Automation Suite requires transitioning through an intermediate version or skiping some versions entirely to maintain the smooth functioning of the internal components. Not following the upgrade guidelines in the previous table may lead to an internal component downgrade or an unsuccessful internal component upgrade, thereby causing the Automation Suite upgrade to fail.
If you plan to upgrade from Automation Suite 2022.10 or earlier, and Process Mining is enabled, you must migrate process apps to the new process graph layout before starting the upgrade.
If you use Active Directory (AD) and are planning on upgrading to 2023.4.0, we highly recommend that you skip straight to the 2023.4.3 version, as 2023.4.0, 2023.4.1 and 2023.4.2 are impacted by an AD issue.
Only upgrades to Automation Suite 2023.10 and later leverage the simplified upgrade process.
