- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Document Understanding Not on the Left Rail of Automation Suite
- Failed Status When Creating a Data Labeling Session
- Failed Status When Trying to Deploy an ML Skill
- Migration Job Fails in ArgoCD
- Handwriting Recognition With Intelligent Form Extractor Not Working
- Exploring Logs
Handwriting Recognition with Intelligent Form Extractor not working or working too slow.
If you are using Intelligent Form Extractor offline, please check to ensure that you have enabled handwriting in the configuration file before installation or enabled it in ArgoCD.
To double check, please go to ArgoCD > Document Understanding > App details > du-services.handwritingEnabled (set it to True).
In an air-gapped scenario, the Document Understanding bundle needs to be installed before doing this, otherwise the ArgoCD sync fails.
Although handwriting in the configuration file is enabled, you might still face the same issues.
handwriting.max_cpu_per_pod
parameter if you have a larger handwriting processing workload. You could update it in the configuration file before installation
or update it in ArgoCD.
For more details on how to calculate the parameter value based on your volume, please check the documentation here.
