2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
Audit events can cause instability (system freeze) if
backlog_wait_time is not set to 1.
For more details, see this issue description.
If the installer fails with the
Automation Suite requires backlog_wait_time to be set 1 error message, take the following steps to set backlog_wait_time to 1.
- Set
backlog_wait_timeto1by appending--backlog_wait_time 1in the/etc/audit/rules.d/audit.rulesfile. - Reboot the node.
- Validate if
backlog_wait_timevalue is set to1forauditctlby runningsudo auditctl -s | grep "backlog_wait_time"in the node.
