- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Responsability matrix
Activity | UiPath responsibility | Customer responsibility |
Hardware & Software prerequisites |
Managing UiPath services, bundled components, and external components
Automation Suite upgrades |
Backup and Restore |
Support |
To ensure administrators are able to efficiently manage Automation Suite, we recommend they come with the following competencies:
Linux system administration.
Network management for configuring DNS, load balancers, managing certificates, security policies, firewalls.
Kubernetes basics to assist troubleshooting.
SQL Server knowledge.
Major cloud providers, if Automation Suite is deployed on cloud infrastructure.
UiPath products.
If you do not have the required technical knowledge in your organisation, we recommend you to explore Automation Cloud.
If you still want to continue with Automation Suite, you can involve our professional services or partners to help you deploy and manage Automation Suite.
For more details, please contact your account manager or the UiPath technical support.
