snapshot-controller-crds pod in CrashLoopBackOff state after upgrade
During an RKE2 upgrade, the newly installed snapshot-controller conflicts with the pre-existing snapshot-controller. As a result, the installation pod for snapshot-controller-crds enters a CrashLoopBackOff state.
Solution
To fix this issue, take the following steps:
  1. Update the /etc/rancher/rke2/config.yaml file with the following details on all server nodes:
    disable:
    - rke2-ingress-nginx
    - rke2-snapshot-controller
    - rke2-snapshot-controller-crd
    - rke2-snapshot-validation-webhook
    disable:
  2. Restart the rke2-server using the following command:
    systemctl restart rke2-server.service
  3. Run the following commands to clean up the existing snapshot controller pods:
    • to clean up the snapshot-controller-crd installation job:
      kubectl delete jobs -n kube-system helm-delete-rke2-snapshot-controller-crd --ignore-not-found
    • to clean up the snapshot-controller installation job:
      kubectl delete jobs -n kube-system helm-install-rke2-snapshot-controller --ignore-not-found
    • to clean up the snapshot-controller deployments:
      kubectl delete deploy -n kube-system snapshot-controller, rke2-snapshot-controller --ignore-not-found
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
