Paso 5: actualizar las cadenas de conexión de los productos migrados
Paso 4.1: generar el archivo cluster_config.json​
Generate the latest cluster_config.json file as follows:
  • Option A: If you have the old cluster_config.json, generate the configuration file from the cluster by running the following command on the server node:
    cd /opt/UiPathAutomationSuite/{version}/installer
    ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.json
  • Option B: If you do not have the old cluster_config.json file, generate an override of any default values resulted during the installation of the previous version by running the following command on the server node:
    ./configureUiPathAS.sh config get -o ./cluster_config.json
Nota:
For details on how to configure the cluster_config.json parameters, see Advanced installation experience.
Paso 5.2: Proporcionar las nuevas cadenas de conexión para los productos instalados​
Debes proporcionar la cadena de conexión de la base de datos a las bases de datos restauradas.
  • Para proporcionar la cadena de conexión restaurada al servicio de Orchestrator, añade o actualiza sql_connection_str en orchestrator en el archivo cluster_config.json :
    "orchestrator": {
      "sql_connection_str": "<dotnet connection string>",   (added line)
      "enabled": true
    "orchestrator": {
      "enabled": true
  • If Test Automation tables are placed inside the standalone Orchestrator database, you can add the same connection string for Test Automation feature inside the cluster_config.json file:
    "orchestrator": {
        "testautomation": {
          "enabled": true,
          "sql_connection_str": "<restored orchesrator connection string>"
      "sql_connection_str": "<restored orchesrator connection string>",   (added line)
      "enabled": true
    "orchestrator": {
        "testautomation": {
          "enabled": true,
      "enabled": true
  • Para proporcionar la cadena de conexión restaurada al servicio de Insights, añade o actualiza sql_connection_str en insights en el archivo cluster_config.json .
    "insights": {
       "sql_connection_str": "<restored connection string>",   (added line)
       "enabled": true }
    "insights": {
       "enabled": true }
  • Para validar si el servicio se migró correctamente, ejecuta el siguiente comando, donde [service-name] es el servicio que deseas validar:
    kubectl -n uipath get secret [service-name]-secrets -o jsonpath='{.data.sqlConnectionString}'
          | base64 --decode
          | base64 --decode
Nota:
Make sure you escape special characters in the connection string's password.
Paso 5.3: Ejecutar el instalador de servicio​
En línea​
Para ejecutar el instalador del servicio en un entorno en línea, ejecuta el siguiente comando en el nodo del servidor:
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreement
Sin conexión​
Para ejecutar el instalador de servicio en un entorno sin conexión, utiliza el siguiente comando en el nodo del servidor:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreement
¿Necesita ayuda? Soporte
