Rotación de credenciales de almacenamiento de blobs
Introducción​
To rotate the blob storage credentials for Process Mining in Automation Suite an administrator will need to have access to the Kubernetes cluster secrets using either kubectl, lens, or another tool. The stored secrets detailed below must be updated with the new credentials, and the the pods for Airflow and Process Mining need to be restarted to make sure all pods for these service receive the new credentials.
Nota:
Las credenciales de almacenamiento deben actualizarse tanto en el espacio de nombres de UiPath como en el espacio de nombres de Airflow .
Nota:
The stored secret values are base 64 encoded. If using kubectl you will need to encode the values before updating them in the cluster. If using Lens (k8slens) then the Lens tooling can do the decode/encode automatically.
Ejemplos​
El siguiente ejemplo muestra cómo actualizar secretos con kubectl:
kubectl patch secret processmining-external-storage-secret -n uipath -p "{\"data\":{\"ACCOUNTKEY\":\"<new_key_b64>\"}}"
Secretos de Ceph​
Espacio de nombres de UiPath
processmining-service-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
processmining-service-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
Airflow NameSpace
airflow-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
airflow-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
ceph-object-store-secret.OBJECT_STORAGE_ACCESSKEY
ceph-object-store-secret.OBJECT_STORAGE_SECRETKEY
Secretos de Minio:​
processmining-external-storage-secret.ACCESSKEY
processmining-external-storage-secret.SECRETKEY
Airflow NameSpace
processmining-external-storage-secret.connection
Secretos de S3:​
Airflow NameSpace
Secretos Azure:​
processmining-external-storage-secret.ACCOUNTNAME
processmining-external-storage-secret.ACCOUNTKEY
Airflow NameSpace
Nota:
Azure connection string is URL encoded; the string will need to be decoded, have the access key updated, then re-encoded.
urlencode -d "wasb%3A%2F%2Fazureuser%40%3Fextra__wasb__connection_string%3DDefaultEndpointsProtocol%3Dhttps%3BEndpointSuffix%3Dcore.windows.net%3BAccountName%3Dazureuser%3BAccountKey%3DACCOUNT_KEY%3BBlobEndpoint%3Dhttps%3A%2F%2Fexample.blob.core.windows.net%2F%3BFileEndpoint%3Dhttps%3A%2F%2Fexample.file.core.windows.net%2F%3BQueueEndpoint%3Dhttps%3A%2F%2Fexample.queue.core.windows.net%2F%3BTableEndpoint%3Dhttps%3A%2F%2Fexample.table.core.windows.net%2F%26extra__wasb__sas_token%3D%26extra__wasb__shared_access_key%3D%26extra__wasb__tenant_id%3D"
urlencode "wasb://azureuser@?extra__wasb__connection_string=DefaultEndpointsProtocol=https;EndpointSuffix=core.windows.net;AccountName=azureuser;AccountKey=ACCOUNT_KEY;BlobEndpoint=https://example.blob.core.windows.net/;FileEndpoint=https://example.file.core.windows.net/;QueueEndpoint=https://example.queue.core.windows.net/;TableEndpoint=https://example.table.core.windows.net/&extra__wasb__sas_token=&extra__wasb__shared_access_key=&extra__wasb__tenant_id="
  • Introducción​
  • Ejemplos​
  • Secretos de Ceph​
  • Secretos de Minio:​
  • Secretos de S3:​
  • Secretos Azure:​
¿Necesita ayuda? Soporte
