OUT OF SUPPORT
Automation Suite Installation Guide
Last updated Nov 21, 2024
Manual: Single-node evaluation profile requirements and installation
This page walks you through the requirements and installation instructions for the single-node evaluation profile.
Deployment Profile Overview
Important:
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath Professional Services.
Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days, and you must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days. For instructions, see Managing certificates.
Federal Information Processing Standard (FIPS) is not compatible with Automation Suite. If FIPs is enabled at any point on the servers running Automation Suite, the cluster will fail. If FIPs is enabled on any cluster server, the installer will encounter issues blocking the installation.
Deployment profile
Prerequisites
Requirements
Configuration
Installation
One Linux machine (RHEL 8.6, 8.8) with ipcalc tool installed
  • Additional Linux machine is required when using Task Mining
  • Additional Linux machine with GPU support is recommended when using Document Understanding
Note:
  • We support new minor versions of RHEL within 90 days of their release.
  • We support SELinux with default policies.
  • Microsoft SQL Server (2016, 2017, 2019, 2022 - Standard and Enterprise editions)
  • Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
DNS
N/A
IPv4
Important:
IPv6 is not supported.
N/A
N/A
Trusted TLS, token-signing and SQL connection encryption certificates
N/A
Proxy server
(optional)
N/A
Kerberos authentication
(optional)
N/A
Attention:
  • You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
  • Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
  • UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
Evaluation or Demo Purposes — Single-node Evaluation Profile Hardware Requirements
Important: Federal Information Processing Standard (FIPS) is not compatible with Automation Suite. If FIPs is enabled at any point on the servers running Automation Suite, the cluster will fail. If FIPs is enabled on any cluster server, the installer will encounter issues blocking the installation.
If you opt for the single-node evaluation profile, you must meet the following hard requirements:
(supported only for evaluation and demo purposes)
Selection
Complete
Basic
Processor
32 (v-)CPU/cores
16 (v-)CPU/cores
RAM
64 GiB
32 GiB
Cluster binaries and state disk for each node
256 GiB SSD
Min IOPS: 1100
256 GiB SSD
Min IOPS: 1100
Data disk for server node
2 TiB SSD
Min IOPS: 1100
512 GiB SSD Min
IOPS: 1100
etcd disk for server node
16 GiB SSD
Min IOPS: 240
16 GiB SSD Min
IOPS: 240
UiPath bundle disk
(For offline installation only, on one of the server nodes)
512 GiB SSD
Min IOPS: 1100
512 GiB SSD
Min IOPS: 1100
Additional agent node for Task Mining (required)
Processor
20 (v-)CPU/cores
N/A
(Task Mining is not present in this selection)
RAM
60 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
Additional agent node with GPU support for Document Understanding
Processor
8 (v-)CPU/cores
N/A
(AI Center is not present in this selection)
RAM
52 GiB
256 GiB SSD
Min IOPS: 1100
Data disk
N/A
GPU RAM
11 GiB
Microsoft SQL Server general requirements
The installation requires an external SQL server as a prerequisite.
Note: Make sure that the SQL server can be accessed from each cluster VM.
Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
The minimum hardware requirements for Microsoft SQL Server are:
  • 8 (v-)CPU
  • 32 GiB RAM
  • 256 GiB SSD
