新发布内容的本地化可能需要 1-2 周的时间才能完成。
Linux 版 Automation Suite 安装指南
上次更新日期 2026年4月28日
集群还原或回滚后服务运行状况不佳
描述
在集群还原或回滚后,AI Center、Orchestrator、Platform、Document Understanding 或 Task Mining 可能运行不正常,RabbitMQ Pod 日志显示以下错误:
[root@server0 UiPathAutomationSuite]# k -n rabbitmq logs rabbitmq-server-0
2022-10-29 07:38:49.146614+00:00 [info] <0.9223.362> accepting AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672)
2022-10-29 07:38:49.147411+00:00 [info] <0.9223.362> Connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672) has a client-provided name: rabbitConnectionFactory#77049094:2100
2022-10-29 07:38:49.147644+00:00 [erro] <0.9223.362> Error on AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672, state: starting):
2022-10-29 07:38:49.147644+00:00 [erro] <0.9223.362> PLAIN login refused: user 'aicenter-service' - invalid credentials
2022-10-29 07:38:49.147922+00:00 [info] <0.9223.362> closing AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672 - rabbitConnectionFactory#77049094:2100)
2022-10-29 07:38:55.818447+00:00 [info] <0.9533.362> accepting AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672)
2022-10-29 07:38:55.821662+00:00 [info] <0.9533.362> Connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672) has a client-provided name: rabbitConnectionFactory#2100d047:4057
2022-10-29 07:38:55.822058+00:00 [erro] <0.9533.362> Error on AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672, state: starting):
2022-10-29 07:38:55.822058+00:00 [erro] <0.9533.362> PLAIN login refused: user 'aicenter-service' - invalid credentials
2022-10-29 07:38:55.822447+00:00 [info] <0.9533.362> closing AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672 - rabbitConnectionFactory#2100d047:4057)
解决方案
要解决此问题,请检查是否由于 Mnesia 表数据写入问题,部分或所有 RabbitMQ Pod 处于 CrashLoopBackOff 状态。
如果所有 Pod 都在运行,请执行以下步骤:
  1. 删除 RabbitMQ 中的用户:
    kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl  list_users -s --formatter json | jq '.[]|.user' | grep -v default_user | xargs -I{} kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl delete_user {}
  2. 删除 UiPath 命名空间中的 RabbitMQ 应用程序密码:
    kubectl -n uipath get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n uipath delete secret {}
  3. 删除 RabbitMQ 命名空间中的 RabbitMQ 应用程序密码:
    kubectl -n rabbitmq get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n rabbitmq delete secret {}
  4. 通过 ArgoCD 同步 sfcore 应用程序并等待同步完成:
    文档图像
  5. 对 UiPath 命名空间中的所有应用程序执行首次重新启动:
    kubectl -n uipath rollout restart deploy
如果某些 Pod 处于 CrashLoopBackOff 状态,请执行以下步骤:
  1. 确定哪些 RabbitMQ Pod 卡在 CrashLoopBackOff 状态,并检查 RabbitMQ CrashLoopBackOff Pod 日志:
    kubectl -n rabbitmq get pods
    kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>
  2. 检查前面命令的输出。如果问题与 Mnesia 表数据写入有关,您应该会看到类似于以下内容的错误消息:
    Mnesia('rabbit@rabbitmq-server-0.rabbitmq-nodes.rabbitmq'): ** ERROR ** (could not write core file: eacces)
     ** FATAL ** Failed to merge schema: Bad cookie in table definition rabbit_user_permission: 'rabbit@rabbitmq-server-0.rabbitmq-nodes.rabbitmq' = {cstruct,rabbit_user_permission,set,[],['rabbit@rabbitmq-server-2.rabbitmq-nodes.rabbitmq','rabbit@rabbitmq-server-0.rabbitmq-nodes.rabbitmq','rabbit@rabbitmq-server-1.rabbitmq-nodes.rabbitmq'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667351034020261908,-576460752303416575,1},'rabbit@rabbitmq-server-1.rabbitmq-nodes.rabbitmq'},{{4,0},{'rabbit@rabbitmq-server-2.rabbitmq-nodes.rabbitmq',{1667,351040,418694}}}}, 'rabbit@rabbitmq-server-1.rabbitmq-nodes.rabbitmq' = {cstruct,rabbit_user_permission,set,[],['rabbit@rabbitmq-server-1.rabbitmq-nodes.rabbitmq'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667372429216834387,-576460752303417087,1},'rabbit@rabbitmq-server-1.rabbitmq-nodes.rabbitmq'},{{2,0},[]}}
  3. 要解决此问题,请执行以下步骤:
    1. 查找 RabbitMQ 副本的数量:
rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas') 2. 缩小 RabbitMQ 副本:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=merge
kubectl -n rabbitmq scale sts rabbitmq-server --replicas=0 3. 等待所有 RabbitMQ Pod 终止:
kubectl -n rabbitmq get pod 4. 检查待处理的卷快照: kubectl get volumesnapshot -n rabbitmq <crashloopbackupoff_pod_pvc_name> | grep false 5.如果存在任何待处理卷快照,请将其删除: kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name> 6. 查找并删除卡在CrashLoopBackOff状态的 RabbitMQ Pod 的 PVC:
kubectl -n rabbitmq get pvc
kubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name> 7. 扩展 RabbitMQ 副本:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=merge 8. 检查是否所有 RabbitMQ Pod 都运行正常:
  • 描述
  • 解决方案
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
