maestro
Maestro Orchestrate user guide
Vue d'ensemble (Overview)
Maestro Orchestrate capabilities for orchestrating AI agents, robots, and people on the Case, Flow, and BPMN canvases.
What is Maestro Orchestrate?​
UiPath Maestro Orchestrate™ is a cloud-native orchestration platform that orchestrates AI agents, robots, and people across end-to-end business processes.
Maestro Orchestrate offers three canvases:
  • Case for long-running, exception-heavy work that cannot be fully defined upfront.
  • Flux pour les workflows structurés et séquentiels créés par les développeurs.
  • BPMN for standards-based structured process diagrams, using Business Process Model and Notation (BPMN) 2.0.
Case, Flow, and BPMN run on the same Maestro Orchestrate engine and share the same UiPath platform services. They can also work together, so a case can invoke a BPMN process as one of its task types. Choosing a canvas walks through which canvas fits a given scenario.
For short-running automation, where AI agents and APIs work together and each run finishes within 24 hours, use Maestro Automate. Maestro Orchestrate or Maestro Automate? compares the two.
Maestro Orchestrate also supports defining business rules with Decision Model and Notation (DMN), and coordinates multiple actors—including RPA bots, AI tools, and people—within a single process.
Cette approche remplace les tâches d'automatisation déconnectées par des workflows intelligents et gouvernés qui sont plus faciles à gérer, à adapter et à mettre à l'échelle.
Capacités Enterprise​
Designed for enterprise use, Maestro Orchestrate supports complex, long-running workflows with:
  • Surveillance en temps réel et contrôle centralisé
  • Surveillance des instances en direct, y compris la mise en pause, la reprise et la réessai
  • Analyse détaillée et optimisation continue grâce à Process Mining
  • Outils de conformité intégrés pour une orchestration gouvernée
By providing a single platform to orchestrate agentic workflows, Maestro Orchestrate helps organizations improve operational efficiency, reduce manual work, and accelerate digital transformation.
Cette vidéo montre comment le processus de montage de prêt évolue étape par étape - d'un simple diagramme de haut niveau à un flux entièrement orchestré et piloté par un agent.
Maestro Orchestrate serves as a mechanism to enhance the performance of your automated workforce and systems. It combines process data with task and automation-level data to better understand your processes.
This video demonstrates how to use the Instance Management view in Maestro Orchestrate to monitor an invoice processing workflow.
  • What is Maestro Orchestrate?​
  • Capacités Enterprise​
  • Rubriques connexes​
