Cómo desinstalar el clúster
Si experimentas problemas específicos de Kubernetes en el clúster, puede desinstalar directamente el clúster rke2.
  1. Dependiendo del perfil de instalación, ejecuta uno de los siguientes comandos:
    1.1. En una instalación en línea, ejecuta el siguiente script con privilegios elevados, es decir sudo, en cada nodo del clúster. Esto desinstalará los nodos.
    function remove_rke2_entry_from_exclude() {
      local current_exclude_list new_exclude_list
      YUM_CONF_FILE=$1
      if [[ ! -s "${YUM_CONF_FILE}" ]];
      then
        # File is empty
        return
      fi
      current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1)
      if echo "$current_exclude_list" | grep -q 'rke2-*';
      then
        if [[ -w ${YUM_CONF_FILE} ]];
        then
          new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}")
          new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}")
          new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}")
          sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}"
          echo "${new_exclude_list}" >> "${YUM_CONF_FILE}"
        else
          error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work."
        fi
      fi
    function enable_rke2_package_upgrade() {
      remove_rke2_entry_from_exclude /etc/dnf/dnf.conf
      remove_rke2_entry_from_exclude /etc/yum.conf
    service_exists() {
        local n=$1
        if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then
            return 0
        else
            return 1
        fi
    if service_exists rke2-server; then
      systemctl stop rke2-server
      systemctl disable rke2-server
    fi
    if service_exists rke2-agent; then
      systemctl stop rke2-agent
      systemctl disable rke2-agent
    fi
    if [ -e /usr/bin/rke2-killall.sh ]
    then
        echo "Running rke2-killall.sh"
        /usr/bin/rke2-killall.sh > /dev/null
    else
        echo "File not found: rke2-killall.sh"
    fi
    if [ -e /usr/bin/rke2-uninstall.sh ]
    then
        echo "Running rke2-uninstall.sh"
        /usr/bin/rke2-uninstall.sh > /dev/null
    else
        echo "File not found: rke2-uninstall.sh"
    fi
    crontab -l > backupcron
    sed -i '/backupjob/d' backupcron > /dev/null
    crontab backupcron > /dev/null
    rm -rf backupcron > /dev/null
    rm -rfv /usr/bin/backupjob > /dev/null
    rm -rfv /etc/rancher/ > /dev/null
    rm -rfv /var/lib/rook/ > /dev/null
    rm -rfv /var/lib/longhorn/ > /dev/null
    rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null
    umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true
    rm -rfv /var/lib/rancher/* > /dev/null
    while ! rm -rfv /var/lib/kubelet/* > /dev/null; do
      findmnt --list   --submounts  -n -o TARGET  --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins'  | xargs -r umount -f -l
      sleep 5
    done
    umount -l -f /var/lib/kubelet
    rm -rfv /datadisk/* > /dev/null
    umount -l -f /datadisk
    rm -rfv ~/.uipath/* > /dev/null
    rm -rfv /etc/sysconfig/rke2-server > /dev/null
    rm -rfv /etc/sysconfig/rke2-agent > /dev/null
    mount /var/lib/rancher
    mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a
    echo "Uninstall RKE complete."
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    then
    else
    fi
    then
    else
    fi
      sleep 5
    done
    1.2 En una configuración sin conexión, ejecuta el siguiente script con privilegios elevados, es decir sudo, en cada nodo del cluster. Esto desinstalará los nodos.
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    if [ -e /usr/local/bin/rke2-killall.sh ]
    then
      /usr/local/bin/rke2-killall.sh > /dev/null
    else
    fi
    if [ -e /usr/local/bin/rke2-uninstall.sh ]
    then
      /usr/local/bin/rke2-uninstall.sh > /dev/null
    else
    fi
      sleep 5
    done
      YUM_CONF_FILE=$1
      then
        # File is empty
        return
      fi
      then
        then
        else
        fi
      fi
    service_exists() {
        local n=$1
            return 0
        else
            return 1
        fi
    fi
    fi
    then
    else
    fi
    then
    else
    fi
      sleep 5
    done
  2. Ejecuta el siguiente proceso de limpieza para discos OSD:
    Importante:
    Para las versiones de Rook-Ceph ≥ 1.16, se cambia el procedimiento de limpieza de OSD. Para obtener más información, consulta la documentación oficial de Rook.
    for osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do
      devName=$(basename "${osddisk}")
      devPath="/dev/${devName}"
      sgdisk --zap-all "${devPath}"
      dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync
      blkdiscard "${devPath}"
    done
    ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove %
    rm -rf /dev/ceph-*
    rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rules
    done
    rm -rf /dev/ceph-*
    1. Reinicia el nodo tras desinstalar.
    Importante:
    Al desinstalar uno de los nodos del clúster, debes ejecutar el siguiente comando: kubectl delete node <node_name>.Esto elimina el nodo del clúster.
¿Necesita ayuda? Soporte
