uipathctl reference guide
uipathctl manifest diff
Compare configuration to live cluster configuration in Automation Suite.
Description​
Load the configuration provided as argument and compare it to the configuration found live in the cluster.
Without any flags, only the manifest is compared,whereas cluster-wide configurations and dependencies are ignored.
The output is always YAML. By default, the diff command available in your path runs with the -u (unified diff), -N (treat absent files as empty), and --color (color output). Add the --no-color flag to disable color output.
uipathctl manifest diff PATH [flags]
Examples​
# Diff manifest found in input.json
uipathctl manifest diff input.json
# Diff manifest found in input.json, using the configuration found in cluster.kubeconfig
uipathctl manifest diff input.json/cluster_config.json --kubeconfig cluster.kubeconfig
# Diff manifest found in input.json, including cluster wide configurations and dependencies
uipathctl manifest diff input.json/cluster_config.json --include-dependencies --include-config
Options​
  -h, --help                   help for diff
      --include-config         include cluster wide config in the diff
      --include-dependencies   include dependencies in the diff
      --no-color               disable color output
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
