uipathctl reference guide
uipathctl health
Health check subcommands for printing component health status.
Description​
Print the health of a component.
uipathctl health [flags]
Options​
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for health
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text,junit] (default text)
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
