uipathctl reference guide
uipathctl cluster migration import
Import the cluster state from local directory to target cluster in Automation Suite.
Description​
The command executes the migration from a source directory to a target cluster.
uipathctl cluster migration import [flags]
Examples​
# Import the cluster state from local directory to cluster
Options​
  -h, --help              help for import
      --versions string   path to versions file
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
