uipathctl reference guide
uipathctl config tls-certificates get
Get TLS certificates from cluster in Automation Suite.
Description​
Get TLS certificates observed in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config tls-certificates get [flags]
Examples​
# Get the current tls certificates from the cluster
# Get the current tls certificates from the cluster with additional certificate information
uipathctl config tls-certificates get --show-details
# Get the current tls certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config tls-certificates get --kubeconfig cluster.kubeconfig
Options​
  -h, --help               help for get
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --show-details       if true, additional tls certificate information will be printed
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
