uipathctl reference guide
uipathctl config argocd registry
Registry secret subcommands for managing ArgoCD registry secrets.
Description​
Manage registry secrets for ArgoCD.
Options​
  -h, --help   help for registry
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
