uipathctl reference guide
uipathctl config token-signing-certificates update
Update future token signing certificate in Automation Suite.
Description​
Update the future Token Signing certificate providing the pfx and key as arguments.
If the provided key is encrypted, use the --password flag specifying the decryption password.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config token-signing-certificates update [flags]
Examples​
# Update the token signing certificate with the provided certificate path and key path from the cluster
uipathctl config token-signing-certificates update --cert server.crt --key server.key
# Update the token signing certificate with the provided certificate path and encrypted key path from the cluster
uipathctl config token-signing-certificates update --cert server.crt --key server.key --password password
# Update the token signing certificate with the provided certificate path and key path from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates update --cert server.crt --key server.key --kubeconfig cluster.kubeconfig
# Update the token signing certificate with the provided pfx certificate
uipathctl config tls-certificates update --pfx-cert certificate.pfx --password password
Options​
      --cert string       path to certificate
  -h, --help              help for update
      --key string        path to certificate key
      --password string   password for encrypted key
      --pfx-cert string   path to certificate in pfx format
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
