uipathctl reference guide
uipathctl registry
Docker registry subcommands for managing container registry.
Description​
Manage the docker registry server.
uipathctl registry [flags]
Options​
  -h, --help   help for registry
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
