uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl manifest get
Get current manifest from cluster in YAML format in Automation Suite.
Get prints on stdout the current manifest observed in the cluster. The format is always YAML.
The command will default to the current context in the kubeconfig file. If the --kubeconfig flag is set, it will use the kubeconfig file specified by the flag. Without other flags, the cluster wide configurations and dependencies are not included in the output.
uipathctl manifest get [flags]
Examples
# Get the current manifest observed in the cluster, without dependencies or cluster wide configurations
# Get the current manifest from the cluster identified by the current context in the kubeconfig file
uipathctl manifest get --kubeconfig /root/kubeconfig
# Get the current manifest, including the cluster wide configurations and the dependencies
uipathctl manifest get --include-config --include-dependencies
Options
-h, --help help for get
--ignore-errors ignore errors when getting the manifest
--include-config include cluster wide config in the diff
--include-dependencies include dependencies in the diff
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
-o, --output output output format. one of [json,yaml] (default yaml)
