uipathctl reference guide
uipathctl cluster migration run
Execute cluster migration from source cluster to target cluster in Automation Suite.
Description​
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
  1. Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
  2. The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]
Examples​
# Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
uipathctl cluster migration run input.json/cluster_config.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context>
Options​
  -h, --help                       help for run
      --namespace string           The namespace where UiPath Automation Suite is deployed (default "uipath")
      --skip-inbound-data          skip inbound data migration
      --skip-outbound-data         skip outbound data migration
      --skip-pre-reqs              skip prerequisite checks for data migration
      --target-context string      name of kubeconfig context to use for target cluster
      --target-kubeconfig string   target cluster kubectl configuration file
      --versions string            path to versions file
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
