uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl rke2 install
Install UiPath components in Automation Suite on Linux.
Install UiPath components.
uipathctl rke2 install [flags]
Options
--accept-license-agreement Accept the license agreement
-d, --debug Run in debug mode
-h, --help help for install
-i, --input string Specify input json file
-k, --install-kubernetes Install Kubernetes and infrastructure modules
-j, --join-node string Type of node to be joined to an existing cluster
--kubeconfig string Specify path to the kubeconfig file
-m, --machines string Comma separated IP address / hostnames of all the machines
-o, --output string Specify output json file
--region string Specify region label value
-r, --restore Setup Restore
--skip-packages-install Disable installation of package dependencies(helm, jq, etc.)
--skip-pre-reqs Skips pre-requisite checks during install
--zone string Specify zone label value
