uipathctl reference guide
uipathctl config saml-certificates rotate
Rotate SAML certificates by exchanging current with future in Automation Suite.
Description​
Rotate exchanges the current SAML data with the future one.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates rotate [flags]
Examples​
# Rotate the saml certificates from the cluster
uipathctl identity rotate-saml-certificates
# Rotate the saml certificates from the cluster identified by the current context in the kubeconfig file
uipathctl identity rotate-saml-certificates --kubeconfig cluster.kubeconfig
Options​
  -h, --help               help for rotate
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
