uipathctl reference guide
uipathctl registry seed-internal-registry
Seed internal registry and RKE agent directory in Automation Suite.
Description​
Seed internal registry and rke agent directory.
uipathctl registry seed-internal-registry [flags]
Options​
  -h, --help           help for seed-internal-registry
  -i, --input string   Specify input json file
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
