uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl manifest apply
Apply configuration to cluster and drive state to desired state in Automation Suite.
Load the configuration found at PATH, and apply it to the cluster.
The command performs a diff between the current state of the cluster and the desired state, and applies the changes to the cluster.
When the --override flag is present, the list overrides the selection found in the input file. The flag is mutually exclusive with the --only flag. When the exclude_components key is present in the input file, the components found in the list are excluded from the installed components. This has the highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl manifest apply PATH [flags]
Examples
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl manifest apply input.json/cluster_config.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl manifest apply input.json/cluster_config.json --kubeconfig cluster.kubeconfig --versions versions.json
# Simulate the apply command and print on stdout the result of the operation
uipathctl manifest apply --dry-run input.json/cluster_config.json --versions versions.json
# Apply the configuration but skip the components installed directly by helm
uipathctl manifest apply --skip-helm input.json/cluster_config.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
Options
--component-timeout duration timeout for individual components to be ready (default 15m0s)
--continue-on-error if true, continue applying the manifest even if an error occurs
--dry-run if true, just print the result of the command, without applying it
--fail-on-version if true, fail if the version of the component is not found in the versions file
-h, --help help for apply
--no-wait if true, return immediately after the ArgoCD applications are created
--only strings optional exclusive list of components to apply, doesn't touch the dependent components
--override strings optional list to override the components enabled in input.json file
--skip-helm if true, skip components installed directly by helm
--skip-oss-prereq if true, skip OSS components prerequisites checks
--versions string path to versions file
