uipathctl reference guide
Last updated Nov 11, 2025
uipathctl health diagnose
Diagnose the last unsuccessful sync operation using the Kubernetes API.
uipathctl health diagnose PATH [flags]uipathctl health diagnose PATH [flags]
Examples
# Diagnose the last unsuccessful sync operation
uipathctl health diagnose input.json# Diagnose the last unsuccessful sync operation
Options
-h, --help              help for diagnose
  -v, --verbose           verbose output
      --versions string   path to versions file  -h, --help              help for diagnose
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
      --timeout duration    timeout of the command (default 5h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
