uipathctl reference guide
uipathctl cluster maintenance enable
Enable maintenance mode for the cluster in Automation Suite.
Description​
Enable maintenance mode for the cluster.
uipathctl cluster maintenance enable [flags]
Options​
  -h, --help               help for enable
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
