- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
Load the configuration provided as argument and compare it to the configuration found live in the cluster.
Without any flags, only the manifest is compared,whereas cluster-wide configurations and dependencies are ignored.
The output is always
YAML. By default, the diff command available in your path runs with the -u (unified diff), -N(treat absent files as empty), and --color (color output). Add the --no-color flag to disable color output.
uipathctl manifest diff PATH [flags]uipathctl manifest diff PATH [flags]# Diff manifest found in input.json
uipathctl manifest diff input.json
# Diff manifest found in input.json, using the configuration found in cluster.kubeconfig
uipathctl manifest diff input.json/cluster_config.json --kubeconfig cluster.kubeconfig
# Diff manifest found in input.json, including cluster wide configurations and dependencies
uipathctl manifest diff input.json/cluster_config.json --include-dependencies --include-config
-h, --help help for diff
--include-config include cluster wide config in the diff
--include-dependencies include dependencies in the diff
--no-color disable color output -h, --help help for diff
--no-color disable color output --context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 5h0m0s)
--versions string optional path to versions file --context string name of the kubeconfig context to use
