uipathctl reference guide
uipathctl config kubeconfig
Kubernetes context subcommands for managing kubeconfig.
Description​
Manage Kubernetes context.
Options​
  -h, --help   help for kubeconfig
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
