uipathctl reference guide
uipathctl cluster maintenance
Cluster subcommands for performing maintenance operations in Automation Suite.
Description​
Perform maintenance operations on the cluster.
uipathctl cluster maintenance [flags]
Examples​
# Enable maintenance mode for the cluster
uipathctl cluster maintenance enable
# Disable maintenance mode for the cluster
uipathctl cluster maintenance disable
# Check if the cluster is in maintenance mode
uipathctl cluster maintenance is-enabled
Options​
  -h, --help   help for maintenance
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
