uipathctl reference guide
uipathctl resource
Resource reporting subcommands for analyzing cluster resources.
Description​
Resource-related commands.
uipathctl resource [flags]
Options​
  -h, --help   help for resource
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
